跳转到主内容
加入维修社区 - 创建账户
这是一系列帮助修理洗衣机的指南和支持。
Laundry washing machine doesn't keeps water
Hello friends
Laundry washing machine doesn't keeps water so waters comes from inside and in same time goes out from drain. Please help me to fix it I'm single mom no enough money
It's Philips 202
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Sounds like the machine is stuck in the drain cycle..you can try a couple of things.Switch off from mains...
Look at the bottom at the front of the machine and locate the "pennytrap" this is usually a cap that screws on but put a towel on the floor and a small bowl to collect any surplus water as you unscrew this cap...sometimes the pipe can be pulled out to help drain into a bowl....now look inside and retrieve any buttons or coins that may have gotten stuck.Replace cap and just put machine into a quick cycle rinse and spin.if it stills refuses to fill then it could be the pressure switch.this is basically a pipe that leads from the pump to the drum.this is usually full of air and works when the drum fills causing the air pressure inside the tube to build up and trip the switch off...thus shutting the fill cycle off ..you need to disconnect the pipe and drain out any fluid so that there is only air inside the tube and reconnect....then quick rinse and spin to see if that cures it....as a last resort tap the drain pump with a wooden hammer just enough to dislodge the impeller which could be stuck open thereby causing the machine to continually drain without filling.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
asad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 52
