跳转到主内容
所有制造商和服务提供商的手机的维修指南和拆解信息,包括苹果 iPhone 和三星 Galaxy 系列。 获取您亲手维修手机所需的一切资料。
73641 个问题 查看全部
Double sided tape for phone repair
I don't fix phones very often, but when I do, I usually use some thin clear double sided tape to adhere or fix some components. It's been so long since I purchased this thin double sided tape, that the store closed that I purchased it from! LOL.
What tape do you guys use / where do you get it from?
I searched through ifixit store and some local stores such as homedepot and kmart, but I didn't quite find what I was looking for.
I found the Tesa 61395 Tape in your store, but I've never used it. I am a bit partial to the clear tape, because I find it used on so many tiny electronics.
Many thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
This question was migrated from http://meta.ifixit.com/Answers.
完成的
添加一条评论
2个答案
已选择的解决方案
I personally use PET Heat Resistant Double Sided tape from eBay (The Tesa red double sided tape variant is better from iFixit).
Works greats for tablets with large surface area for adhesive.
For the smaller devices I use TESA 61395 double sided tape.
这个答案有帮助吗?
得分 3
1条评论:
Thanks! I'll take a look at them.
完成的
添加一条评论
Would this stuff work? https://www.amazon.com/XFasten-Double-Re...
这个答案有帮助吗?
得分 1
5条评论:
It looks promising, but it appears quite opaque. I know it sounds crazy, but I swear 3M used to make sheets of this clear double sided tape. I think it may be 3M 8153LE. I think the last time I purchased it, I was barely double digits lol. Thanks
完成的
Yup. That looks like it. Thanks.
完成的
No problem just copied and pasted model number into amazon.
完成的
Got ya. Yeah that's what came up when I searched for something similar on amazon and ebay. I'm going to leave this post unanswered for a few days to see if anyone uses something similar. I needed some double sided tape to finish a repair tonight, so I just went ahead and got the standard yellow-box scotch double sided tape from kmart. It's transparent and pretty close to the stuff I had, but not exactly the same.
完成的
添加一条评论
添加你的答案
Anthony Kouttron 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 39
过去 30 天: 140
总计 19,149
