跳转到主内容
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
220 个问题 查看全部
iPad mini 2 won’t charge
I’ve since replaced the battery and was initially very pleased to see it turn on. Then, the shocker; it has power, which I assume was loaded on the battery before shipping, but it still will not charge.
I’m guessing the problem therefore actually lies with the lightning port in the iPad. I would be happy to also replace this, but... what am I looking for to order/replace?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
They are soldered into place, so unless you can do logic board repair its not going to be one you can do, as I pretty much guarantee you'll end up pulling pads when you remove the old port from the board.
First thing id do is get a microscope or magnifying glass and check you have nothing in the charge port at the back. Then check if you have any broken or bent pins inside the charge port.
If the charge port looks ok its unlikely that its the port, its not like the iphone ports that have components on them, the ipad flex is basically just a wire with a plug on the end so not really much that can go wrong with it.
If its not the charge port its going to be a component on the motherboard, so you need to speak to someone in your area that does logicboard repairs.
The mini 2 does have the same piece of cr*p power management chip the air 1 also has which does suffer from charging problems, so could be fun to fix if thats the case.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jeffrey Rarey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 11
总计 2,119
