跳转到主内容
加入维修社区 - 创建账户
The Kenmore Direct Drive is a washing machine by Kenmore.
Washer won't agitate, fills with water & will spin, but hums elsewhere
EDIT: It seems like it's problem is going from rinse to spin. Ran it through a small cycle and stops right after rinse. It makes that hum, then shuts off. There is a burnt smell, but not that bad. Ironically, going from cycle to spin works fine.
My working theory is the transmission, as it does make a bit of a rattling noise at agitation. Video: https://youtu.be/POABtLbIPts and when going into the second spin, it seems like everything locks up.
Video of the machine locking up: https://youtu.be/QzH00JX6Kxc
Spin works fine, but anything else just hums. Finding a bunch of answers & good places to start, but something's still not connecting.
First thought was something is locking the drive and tripping the motor. BUT, I take the belt off and the motor will not engage except on spin.
This is actually an Amana, but couldn't find a suitable appliance.
Thoughts anyone?
This was the closest & best read I've found, but has a lot of options.
Washer fills with water, doesn't agitate but will spin out water?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
You have a bad bearing issue and the motor windings are bad. Most washer motors turn one direction to wash then reverse to spin, or they wash on one speed and spin on another. Each uses different motor windings.. The motor can operate in one direction fine but if the windings are bad in the other direction or speed it wont. Usually, with that much noise, you will find the center seals are bad, thus, causing a leak, rust, shorted windings etc. Look for any signs of a water leak underneath coming from the center of the tub. If you see signs of even a small leak you will need to replace the seals so it doesn't destroy whats left.
这个答案有帮助吗?
得分 2
1条评论:
Baxter- if you could do another video and have more light on the transmission and motor area that would be great! Keep us updated. Thanks
完成的
添加一条评论
I would check the float switch. Has a tube going to the washer tube and electrical lines going to the timer. The next is check the lid switch see if it is closing and completing the circuit. Ralph Fremont Calif
这个答案有帮助吗?
得分 0
1条评论:
Thanks for the response. I edited the original response. Still think it's the float switch?
完成的
添加一条评论
Well, unfortunately, it was the transmission. Given the appliances were 12years old+, other items were apt to follow going out, so I bought it all.
It would be different if it wasn't such a critical piece of a household of 5.
Thanks all for the input.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Baxter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 37
总计 14,145
