跳转到主内容
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
114 个问题 查看全部
My computer will not read the airport card, what should I do?
I just recently purchased an airport card for my Ibook G3. I put in the card and the computer makes the noise like it is going to start up and then does nothing, the screen remains black. I thought it might be the airport card, but I put the card in an older G3 Ibook and it worked just fine. What is wrong with the computer, do I need to replace the card reader of this Ibook?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Could be a damaged bus or slot on the wireless portion of the logic board. If you have a known good slot you could try replacing it.. other wise you could try to find/use a USB wireless adaptor.
Good Luck,
N.
这个答案有帮助吗?
得分 1
1条评论:
Part number for the replacement slot (sold by ifixit) is
[关联产品丢失或禁用: IF150-038-1]
Good luck. Ralph
完成的
添加一条评论
添加你的答案
Levi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 671
