跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
troubles with home button after changing front panel
Hi all,
This is my first fixing with ifixit.
I have an old Iphone 5 with brocken screen so I bought the front panel from the website together with tools.
Everything works good untill I switch the phone on after the replacement. The home button doesn't work.
As the reassembly instructions are only the step back , I was really wondering if I had done the right things.
How do I ensure that the 2 golden dots are aligned with their counterparts on the back panel?
How do you ensure that the golden dots are "reglued" correctly?
Thanks for your help
B
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Have you followed this specific guide?
Check out Step 23 to see how the pads should be placed. There should be sufficient residual adhesive to allow them to properly stick to the new screen.
I would also check Step 12 and look at the bottom-center of the image. Those gold "fingers" are what make contact with the pads. Make sure they are bent ini such a way that they can contact the pads. Be careful as they can break easily.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Baptiste Le Sueur 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 45
