跳转到主内容
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573 个问题 查看全部
Custom icons have reverted to blue folders
Upon updating to High Sierras, all but a handful of my custom desktop icons reverted to the standard blue folder icons. When I go to download new custom icons and follow the replace procedure (open, get info, copy image, paste image to replace blue folder image), this is what happens: I select "get info" and all I get is a "preview" icon. I tried copying and pasting that, but if I do, the "preview" icon becomes my folder's image. I have no idea why this has happened, nor how to fix it.
Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
What is your system model?
完成的
It is a new iMac Intel 27", Retina 5K, 3.4GHz.
完成的
添加一条评论
1个答案
最有帮助的答案
In the older OS9 we often needed to rebuild the desktop as the data structure between the icon & application/data file ID would get messed up as they where held in different structures. In OS-X & MacOS there is no means to rebuild the icon to file association as the data file is now one structure.
Sadly I suspect your drive has some issues!
So what to do??
First make a proper backup using TimeMachine (we don't want a image clone).
Next create if you don't have one an external bootable drive a USB thumb drive will work. A bootable OS installer drive will also work as you may need to re-install a fresh OS. Follow this guide: How to create a bootable macOS High Sierra installer drive
I might add if you have a SATA SSD drive I would recommend you stick with MacOS Sierra as Apple's new APFS has issues with SATA based SSD's (remember High Sierra forces you to upgrade to APFS)
OK, You now have the bootable drive Boot up with it and then run Disk Utility from it. Don't use the onboard recovery services diagnostics as it can't alter the deeper levels of the drive. If the drive can't be saved you'll need to reformat it and install a fresh copy of OS.
这个答案有帮助吗?
得分 3
2条评论:
I greatly appreciate your answer. However, I do not believe the drive has issues. This is a new computer. All else works perfectly. Only the folder icons reverted to the plain blue folder icons.
However, I am not doubting what you said. But since this is under warranty, I would rather make sure that what you suggest sound correct to Apple technicians, which it very well may.
The problem is, is that SOME icons (they were part of a set -- different exotic flowers) work FINE, as do other random ones. This is a mystery to me. So, it is not across the board. That's what so odd about this.
完成的
I said your drive has issues, that does not mean you have a bad drive! Your OS is corrupted here.
I would follow the steps I outlined here or bring it in to an Apple Store and let them deal with it.
I would also recommend you double check your power outlet you are using for your system. Make sure its properly grounded and you might want to get a UPS as the power may not be stable enough (a possible cause of your corruption).
完成的
添加一条评论
添加你的答案
Tatami 53 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 546
