跳转到主内容
The OP-1 is a portable music workstation incorporating a synthesizer, sampler, sequencer, multitrack recorder, drum machine, mixer, and controller. It was released in 2011.
Why is my OP-1 not turning on?
I have been storing my OP-1 and using it since 2013. The other week it stopped turning on; currently, when I flip the power switch, I hear the power get to the speaker but the screen does not glow at all. Is this a screen issue, ui issue, or is it something else? It has turned on previously but it only works after I perform a firmware update or sparingly at any other time.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
3条评论
Hello @amccaw1590 , Have you found a fix?
Mine stopped working yesterday night. I thought it was because the battery was empty but when I connected it to my laptop nothing happened.
I hear the power get to the speaker but same, the screen remains black.
I didn't upgrade the firmware. Just use it and then it stopped working :(
I tried to reset the factory settings but didn't work.
Any idea how to fix it?
完成的
Were you able to fix this?
完成的
Hey, has anyone been able to resolve this issue or find a place to diagnose and repair the problem?
完成的
添加一条评论
2个答案
最有帮助的答案
I’ve had this problem as well. I was able to fix using the instructions here:
https://www.reddit.com/r/OP1users/commen...
这个答案有帮助吗?
得分 1
添加一条评论
It has happened a couple times to me and has required a firmware update both times
这个答案有帮助吗?
得分 0
1条评论:
How did you update the fw if it doesnt turn on?
完成的
添加一条评论
添加你的答案
Angelo McCaw 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 30
总计 2,971
