跳转到主内容
Fourth generation Samsung Android tablets. Released in April 2014.
Cannot pair skullcandy with blue tooth
I have used my skullcandy crusher wireless headphones with my tab 4 many times. My headphones needed to be charged, so I did that. I tried to use them again and they didn't work. So I tried to pair them again. The tab would not recognize them as an available device.
A few days ago I had to reset the tab to the factory settings. This is the first time I tried using the headphones since the reset. Would that have caused a problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
I tried everything else and then i read this and it's the only thing that worked! Thanks man!
完成的
Thank you for posting this solution. It totally worked. I am grateful.
完成的
添加一条评论
4个答案
最有帮助的答案
I have encountered a similar problem and here's my solution;
  1. While the headphones are turned 'on' press and hold vol + and vol - at the same time , a blue light flashes.
  2. Turn off the headphones and turn them on again, now instead of a red, you will see a combination of flashing blue and red lights , this means it's in pairing mode
  3. Forget your headphones from previously connected devices list on your tab/phone/etc
  4. Re pair it
  5. Done.
这个答案有帮助吗?
得分 24
16条评论:
Did the above trick, after a few tries i got working. Thanks alot !!
完成的
Just changed phone..and the above worked!thank you so much!
完成的
I did it and it works! Thanks!
完成的
Thanks a million. Appreciate you
完成的
cool it's functioning
完成的
显示更多的11条评论
添加一条评论
You have tried to pair the headphone again after resetting the Tab ?
If not, you need to do that, because the bluetooth connection is not 'paired' anymore.
Usually you need to press some button long on the headphones to go into pairing mode.
这个答案有帮助吗?
得分 0
1条评论:
This was the best answer from all my searches. Solved the problem!
完成的
添加一条评论
I tried several times but couldn't find the hesh 3 in the Bluetooth searches.
这个答案有帮助吗?
得分 0
添加一条评论
I have no idea how this worked, but finally after days of trying, my Method Active bluetooth wireless earbuds actually work with my new Samsung Galaxy android phone! Now if they would only connect to my Dell computer!
这个答案有帮助吗?
得分 0
1条评论:
btw: thanks!!!
完成的
添加一条评论
添加你的答案
Dave Gooding 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 21
总计 22,417
