跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Why sound is not coming from earpiece and hesdphone
hi
my iphone sound is not working with earpiece and headphone during call and voice memo and any where else.... i changed ic sound and retored to 11.2 ios but still i have the problem
plz help me thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi Mehran,
Do you mean you don't get sound from devices other than your iPhone itself?
完成的
no sound from iphone
完成的
添加一条评论
2个答案
已选择的解决方案
I apologise for asking the obvious but have you tried to replace flex components before replacing IC's? It is possible that a bad Lightning/Headphone port could be causing this issue. I would try to replace, preferably with known good parts, the Headphone flex first, then the FCAM/Sensor flex to see if this helps. If you have already tried this and are confident the issue is logic board related, I would double check my work on the Audio IC (U0900) to insure there are no displaced/bridged components surrounding the IC and ultimately, remove the IC and check the pads below for cracks etc. You could also check the relevant filters (page 11 & 18 of the schematic).
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Try using the them in another phone to see whether they work as expected, preferably an iPhone (as some headphones are manufactured for either iPhone or Android devices).
If they behave the same plugged into the other device, then you need to look for headphones with inline mic manufactured for iPhone. Most major brands will offer their headphones in either Android or iPhone version.
If they work with the other device, then it might be an internal hardware fault (assuming you didn't fiddle with the software - as in jailbreaking).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
mehran baloch 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 120
