跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
iPhone SE NFC antenna not working after housing replacement
I replaced my iPhone SE into a clear plastic custom housing shell that i bought online. For picture reference on what i'm even talking about, here is a photo. Everything on the phone functions perfectly, except for the NFC antenna.
I didn't notice this for many months because i rarely ever use apple pay. But i just decided to today and failed to get it working. Everything else on the flex cable works perfectly (volume rockers, mute switch, flash, power button, & vibrator), but nfc doesn't seem to function at all.
Does having a plastic shell inhibit the ability to use NFC? Did i not move a certain part over? Any ideas on how to trouble shoot?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
3个答案
已选择的解决方案
I replaced the housing on my iPhone SE and ran into the same problem — Apple Pay didn’t work. After a lot of troubleshooting, I realized that the NFC antenna contact was misaligned.
This is an old post. I’m posting my solution to spare the next person who runs into this from the headache.
The offending contact is here:
The circled screw secures the NFC antenna (built into the power button flex cable) to the motherboard. Note the small, metal, inverted “J” coming out of the left side of the screw.
That exposed piece of metal, pictured here:
Needs to make contact with the motherboard pad pictured here:
(Ignore the highlights around the two chips. We’re looking at the line on the top left of this photo.)
It’s very easy to either place the motherboard on top of the ribbon or to screw the surfaces together sideways, resulting in poor contact between the two components.
Good luck!
这个答案有帮助吗?
得分 12
4条评论:
You made day!
完成的
Thank You sooooo much for sharing this, You really made my day.
I recently got my phone repaired from Apple and looks like they damaged this screw while replacing my battery.
I reached out Apple to help and they were unable to help me and asked me to buy a new phone, fortunately i read this article and tried to check if this was the issue and to my amazment yes the screw and the whole unit was never screwed in properly so the ApplePay was not working since last few months. I have fixed my phone and left apple and the Autorized service center a feedback
完成的
It's old, but thank you! I had a demo iPhone SE that surprised me when Apple Pay didn't work at the store. I brought it home and did what you described - made sure that the J-shaped metal part contacted with the plate on the motherboard. Took it back to the store and it worked first time.
完成的
Thanks alot. that was helpful
完成的
添加一条评论
The NFC antenna is connected to the Power Button Flex. [Dead link removed]
You may have either damaged the flex, connected it improperly or there is an issue with your replacement housing. Generally speaking, the housing is part of the antenna. If all your other antenna's work, then it may just be one of the first to options above.
这个答案有帮助吗?
得分 4
5条评论:
Yes i understand the whereabouts of the NFC antenna. The flex connector seems to be fine since everything else on the flex works. All of my other antennas work fine (Cellular, LTE, Wifi, & Bluetooth), so i dont really know why only the NFC is broken
完成的
Like I said, generally speaking, the housing is part of the antenna so there may be something wrong with your housing. You may have forgotten a small spacer or used a wrong screw. You could also try to put everything back in the original housing to see if the problem follows the flexes or the housing.
完成的
Unfortunately, if any of the top flex cable buttons fail(sleep/wake for me), no replacement flex appears to have the NFC antenna included. There is video from fixit planet where the operator rips/scrapes the antenna of the original flex and somehow attaches it the new one. It is unclear, especially as it is a critical procedure.
I replaced the flex in an SE but wasn't game to try this brutal option. Everything works now except ApplePay :(
完成的
Same problem here. No replacement flex seems to include the NFC part. I also don't find the NFC part on its own. Does anyone have an idea where to get it?
完成的
I tried replacing the flex cable on my SE when my power button started failing, but the replacement process was too fiddly. I couldn’t get the buttons to line up just right — this caused problems with all of the other buttons on the ribbon. I ended up just buying a replacement rear panel on eBay for ~$10. It’s much easier to transplant the motherboard, battery, etc into a fully assembled rear housing than it is to replace the flex cable.
完成的
添加一条评论
elahd  Thanks dude.
(I use online translator)
Your instuction helped me. The reason for the breakdown was different. Under the NFC connector, near the battery, a sealing parallon has fallen. And modern NFC contact block stopped working.
I cleaned the contact under the bolt (unscrewed from the board, back to the thread retainer) and restored the contact on the connector. NFC is working again.
Other instructions on the Internet did not correspond to reality.
Good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Trans1000 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 113
总计 11,639
