跳转到主内容
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
220 个问题 查看全部
iPad Mini 1 backlight fuse acting weird. Need some help.
I bought an iPad Mini off Ebay that said it had backlight issues. It didn't come with a screen and I bought an LCD screen and digitizer. I did buy genuine Apple replacement parts and didn't buy any after market garbage. The weird thing is when it's dead and I plug it up to charge the screen actually lights up. So the charging battery screen actually shows up with no backlight problems. Once the iPad boot up oddly enough the backlight is gone again. Can't figure out why the backlight works when it's booting and when it actually hit the lock screen it's gone again. Any help would be much appreciated. I haven't had any luck finding someone with this issue online anywhere.
I'm willing to link photos if needed.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It's hard to say exactly what could be causing this without having the device in hand. As you say, if the backlight works for the initial start, it should work overall. It could be a problem with the replacement LCD. You say you purchased high quality replacement parts, which is good, but even those can sometimes be defective.
However, it is possible that the circuit can't handle the current load for extended periods of time. It could also be a problem with the digital logic telling the backlight to shutdown incorrectly. Ideally, you would have to test a known-good LCD first and then probe the logic board if the problem persists. The mini is well known to have backlight issues.
这个答案有帮助吗?
得分 3
2条评论:
Do you have recommendations on who I should send it to be repaired?
完成的
Err...did you not notice my avatar? :-)
There are a few reputable micro-solderers who frequent this forum or you can search Google. You can check out my profile if you'd like, at the very least it will serve as a data point.
完成的
添加一条评论
添加你的答案
Fahrenheight 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 475
