跳转到主内容
加入维修社区 - 创建账户
iPad Mini4 Wi-Fi版型号A1538指南 。iPad Mini3的后继版本iPad Mini4 发布于2015年9月9日。
Fingerprint function does not work
Dear,
I repaired my ipad mini 4 for the first time,
I have an problem with the fingerprint function.
When i replaced the home button and try to test the screen and the function ,my fingerprint does not respond anymore.
I checked in the touch id options and it is not turned of so i think its not broken, also i can just switch it on and off. When i had this problem with an iphone the ios gave an error that the touch id will not work.
Is there any solution for this or what i might did wrong.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Yes, replaced everything original, only the solder part i did not, because i read that the solder thing is for the power button sleep mode
完成的
添加一条评论
1个答案
最有帮助的答案
did you use the original home button, as other home buttons wont let you use touch id, only apple can supply home buttons with touch id
这个答案有帮助吗?
得分 2
1条评论:
The OP may have damaged the flex cable. Even a tiny tear could cause the Touch ID to fail.
完成的
添加一条评论
添加你的答案
glennjacobs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 480
