跳转到主内容
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
220 个问题 查看全部
Touchscreen not working after digitizer replacement
I replaced my digitizer because the glass was cracked. The new digitizer looks very different on the connector part.
New piece:
http://i63.tinypic.com/2a4y77r.jpg
Old piece:
http://i66.tinypic.com/2vc6ql3.jpg
I tried connecting the new piece. The home button works, but not the touchscreen. If I try to use again the old digitizer, everything works fine.
My question is:
as far as you know, is the new piece even compatible with my Ipad mini 2 (model 1490)? When I bought it, the description said it was for that model too.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
I think the issue is there isn't any or sufficient shielding to the ribbon cable and digitizer border.
See how the old piece has some taping, it's minimal but could have more taping.
The new piece needs that yellow kapton tape around here:
Additionally you could wrap it around the yellow marked area at the ribbon cable that plugs into the logic board to keep it nicely in place.
这个答案有帮助吗?
得分 4
1条评论:
Thank you. I didn't plan on buying kapton tape, but when I did it worked. At the beginning I was trying to use the tape from the old screen, but there wasn't enough for the connector part.
Thank you very much, again :)
完成的
添加一条评论
添加你的答案
Elle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,716
