跳转到主内容
Repair guides and support for the eighth generation of Ford F-Series trucks: the F-150, F-250, F-350, and F-Super Duty.
58 个问题 查看全部
both my front blinkers won't work and i've checked the fuses
i've vhecked the fuses and there good, don't know whats wrong, in need of answers.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Brian O'Dell since you are saying to front not working, I am making the assumption that the rear blinkers are working. Check to make sure you have teh right bulbs in the front blinkers first, than check the wiring. The relay used is for the front and rear so that should not be the issue
完成的
添加一条评论
1个答案
最有帮助的答案
did you check the relay looks like the photo
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Brian O'Dell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 42
