跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
MBP does not hibernate at low level but shuts down completely
Hi,
I ordered a non-OEM battery from iFixit (made by Simplo). After installing it, calibrating and SMC resetting my Mac keeps shutting down on low battery (mostly around 10%) instead going to Hibernation. Which is really frustrating for me as none of the work is saved.
Another thing is that the capacity keeps changing even after multiple calibrations.
After this, iFixit sent me a new battery but the problem is still there. Could this be that both batteries are faulty or is it my computer?
Can someone tell me what is the issue please?
Nam
Update (12/06/2017)
Dan:
Here you go. One more thing: When the computer shuts down and I plug the cord back, it shows 10% but when unplugged, it dies again. No way to get it on 0%.
Update (12/06/2017)
There it is. took me by surprise so this is the screenshot after plugging the cord back.
Update (12/09/2017)
Notice how the max capacity changes all the time.
Update (12/10/2017)
Hi everyone, well the problem fixed itself I guess. It took several calibrations but it should be ok now. The mac hibernates now, however the capacity of the battery shows 7985, although ifixit guarantees greater than 8250...
Update (12/13/2017)
Well it turns up that the problem is not solved at all. The battery keeps shutting down even though it hibernated last time. I’m going to return it.
Thanks for your effort.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
9条评论
Can you install this gem of an app: CoconutBattery it should tell us what is happening here. Paste a screenshot of the main window in your question so we can see what it tells us.
完成的
OK, This looks good! Fully charged.
Run the system down (disconnect the MagSafe adapter) See what you can capture just before it shuts down if you miss it plug the charger in and quickly disconnect it then snap a screenshot again and post it in a new answer.
完成的
Did you make sure to fully charge and discharge the battery for it's first initial setup?
完成的
Anthony - I do believe Do Hoai Nam did: "After installing it, calibrating and SMC resetting my Mac keeps shutting down on low battery"
完成的
Yep I did. Charged it, left it plugged in and used the computer until it shut itself down. Then i left it 5 hours and charged it to max and made a SMC reset. I’m at 25% now so I will soon be able to provide that pre-shutdown screenshot.
完成的
显示更多的4条评论
添加一条评论
1个答案
最有帮助的答案
I don't think you have a battery issue here. The monitoring is part of SMC which uses a comparator to measure the load and the battery. I'm thinking your issue is maybe some wetness or liquid spill which has altered the tuning on this logic.
You'll need to gain access to the logic board and do a through cleaning with 85% or better isopropyl alcohol focusing on the SMC logic.
这个答案有帮助吗?
得分 1
2条评论:
Hi, thanks for suggestion but the problem is, that when I plug the OEM battery back in, it works as intended. (Goes to hibernation at low battery)
完成的
iFixit batteries are as good as OEM. Can you test the battery with a multi meter? If the voltage is correct (10.95v) then the battery is good. The SMC might not be recognising the converted power for the Hibernation state to occur.
完成的
添加一条评论
添加你的答案
Do Hoai Nam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 900
