跳转到主内容
加入维修社区 - 创建账户
发布于2013年11月22日的微软第三代Xbox游戏主机。
Xbox One Sync Button Doesn't Work Properly
Okay so my Xbox One has been working fine since I've gotten it earlier this year. Just recently, the sync button stopped working. When you take off the panel on the side, the black triangular piece is there. I've tried messing around with almost everything on my Xbox and nothing worked. But now, when I hard reset my Xbox and also unplug the chord from the power box, then I wait 30 seconds. After that, I plug everything back in and turn on my Xbox and the sync button works so I connect my controller. It only stays connected for 15-20 minutes and sometimes less before it ends up disconnecting again and I have to go through the entire process again. My sync button doesn't work again and the Xbox logo on the front doesn't flash like it's supposed to. Oh, also using a USB to connect my controller doesn't work. I'm very frustrated and don't know what to do. Did anyone else ever experience this? Please help!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
Yes same problem…did you ever end up getting this problem sorted? Having the exact same problem
这个答案有帮助吗?
得分 0
3条评论:
I ended up replacing the wifi module if I recall correctly. Was only about $25 and 30 minutes of work. My Xbox has worked flawlessly since then. Hope this helped!
完成的
But I'm still getting wifi connection to th e web and media remot er still works?
完成的
@trimbo92 Its Bluetooth and Wifi I think
完成的
添加一条评论
添加你的答案
super girl 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 4,283
