跳转到主内容
Repair guides and support for the ZTE n817, also known as the ZTE Quest.
70 个问题 查看全部
Why is my mobile network state disconnected
My zte legacy n817 keeps showing disconnected on the mobile network state and it's through qlink wireless it's not letting me make or receive calls or texts its not roaming I have minutes and unlimited text even 1gb data my plan was just refilled and it never has done this before it started two weeks ago out of nowhere and I done went to roaming settings and ping test menu tried changing network's it won't work on any how do I fix this
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I am having the same problem and I have zte l2 blade
and noboday is helping me if thy helped you please help me
完成的
添加一条评论
1个答案
The “Mobile Network State Disconnected” is associated with a poor cellular network or wireless signal reception on the mobile. The problems occur generally either due to a faulty antenna or a corrupt SIM card.
You might have encountered the “Mobile Network State Disconnected” error on your mobile when the mobile is on poor network reception or you are trying to connect to a wifi network as well. Every time you attempt to access the internet a pop-up shows up “Mobile Network State Disconnected” with a close or ok button.
here is the solution: Straightalk phone keeps saying Mobile network state disconnected
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
taniaha 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 1,669
