跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
Screen Damaged - Need advice on what would parts to buy to fix it?
Someone in my household seems to have either stepped or dropped something on my Macbook Pro (13" Retina 2015). While it was closed.
The that took the impact seems to be the top right where the power button is.
The screen is damaged, and understand I can buy a replacement on this site.
I just want to know, from the look of the photos, do you think I need to buy any other parts to fix the problem?
Photo 1
Photo 2
Photo 3
Thanks for any feedback anyone can provide!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Looks like the screen back case is fine if you only want to buy the display itself, but that is going to make it more difficult to change cause you'll have to get the old one all the way out of that back case. If you buy one with the back case it'll be more expensive, but easier to swap, since you'll really only have to take off the entire screen and back case, unplug it from the board, and plug the new one in and attach it to the bottom case(bearing in mind there are other components you'll have to remove and reinstall regardless of which one you buy. Which one you buy will all depends on your level of expertise and confidence.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jared Turner 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 47
