跳转到主内容
型号 A1213或A1218,闪存容量:8、16及32GB
"Unable to join WiFi network" How can I fix this?
So, my iPod Touch 1G just arrived today and for some reason, the WiFi has a weak signal and it says "Unable to connect to the network". Does anyone know how to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Unplug and plug in router. Move close to the router (try this step first). Restart iPod. If all else fail try full erase.
Update (01/13/2018)
Is the iPod used? Or new? A used iPod might need the Wifi antenna replaced or it could’ve come disconnected. Most of those are little (coax) cables but they look different in a phone or ipod/iPad. I wouldn’t suggest doing this yourself because iPods are the hardest Apple device to get into unless you like soldering. Sorry for the late reply. I hole this helps if you’re still having the problem
这个答案有帮助吗?
得分 0
1条评论:
Everything i tried failed, even the reset. What do I need to fix?
完成的
添加一条评论
添加你的答案
superlions16 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 583
