跳转到主内容
Why my front camera icon disappeared?
After a factory reset my front camera icon seems to be disappearing often. And nowadays the front camera icon disappeared completely. I tried factory reset again, but find no use. Kindly help me with a solution.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
Hi Alby,
I was able to do a little research and it appears that you are not the only person with this problem!
According to a question asked on the Google Forum, one of their experts suggest two things:
1) "Try to clear the cache and data of the Camera app. Some have reported this solved some issues they had with the Camera app."
2) For those of you who haven't requested a new device could you boot in safe mode to see if the problem persists.
Ensure your device's screen is on, then press & hold the Power button.
Touch & hold the Power off option in the dialog box.
Touch OK in the following dialog to start safe mode.
I hope this helps!
这个答案有帮助吗?
得分 2
2条评论:
Nothing worked. Tried factory reset, safe mode, cache clean. Still no icon for front camera. I used to have it
完成的
Same problem my lava pixcel v1 I try more time clear cache but no use front camera not disappear
完成的
添加一条评论
Last month 20 may from that date my mobile front camera not working
这个答案有帮助吗?
得分 0
1条评论:
Front camera not working
完成的
添加一条评论
添加你的答案
Alby Issac 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 3,250
