跳转到主内容
加入维修社区 - 创建账户
Repair guides, user manuals, and technical specification for the Acer Aspire 5552. The Acer Aspire 5552 is a budget laptop equipped with a 15.6 inch screen, 250GB of storage, and a DVD writer. A laptop with modest performance for a cheap price.
It won't power up.
I purchased a used Acer aspire 5552 without a charger. Purchased replacement charger. Plugged it in turned it on, have to reset Windows. I turned it off so I could reboot and now when I hit the power button the blue light on the power button comes on, I hear the laptop start (fans and drives) then it just shuts down. I was hoping after a good charge it would start but it still wont. So I looked and you guys say if it charges and won't start probably a battery, but it still won't turn on even when plugged into the power adapter. So help please!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
The battery seems to have a problem. Try changing to another battery or If your warranty is still active try using it.
完成的
添加一条评论
1个答案
最有帮助的答案
Try removing the power adapter and the battery and holding the power button for 10 seconds. Wait 30 seconds and then put the battery back in and see if it boots. Some HP laptops use this procedure as a hard reboot. If this doesn't work, try re-seating the RAM in your laptop.
这个答案有帮助吗?
得分 2
2条评论:
Anthony Kouttron's suggestion usually works in cases like this. You might try leaving it plugged in overnight if it doesn't work immediately after trying it.
完成的
I have an old Acer Aspire 5630 with all my email on it. A few days ago it stopped starting, when I pushed the power button it "started" 1 second and then stopped. Because the battery is as old as the laptop the power supply is always on.
So I followed Anthony's procedure and it worked!! Thanks a lot!
完成的
添加一条评论
添加你的答案
Stacy Prenot 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,652
