跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Sound only working when logic board is presed
This is an update to an older question I have asked since it was pretty vague. So when I was disconnecting the battery of the phone i used a screwdriver which caused a spark and after that the sound would only work if i pressed the area above the sim card slot.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
since you say there was a spark when disconnecting the battery you could have maybe damaged the audio amplifier or surrounding components which is on the other side of the board behind the battery connector and has a path to the battery line ( pp_batt_vcc )
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Axel Salas 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 78
