跳转到主内容
加入维修社区 - 创建账户
Model M5343 / 333 or 400 MHz G3 processor
Inverter Boards and their different blinking habits
Howdy all! I know quite a bit about Lombard PowerBooks and Pismo PowerBooks, but I don't know the answer to this question.
I'm pretty sure that the inverter boards for each model is compatible with one another, but I know that the Lombard sleep like blinks a green light, and the Pismo's green light fades on and off.
If I put a Pismo inverter board, then the Lombard would have a fading light, wouldn't it? Likewise, if I put a Lombard inverter into a Pismo, the light would blink instead of fade, correct? Thanks so much!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
as far as I know, the sleep LED on the powerbooks has nothing to do with the inverter circuit (which instead drives the fluorescent backlight for the LCD display). so swapping the inverter module between models of PB should have no effect on the pulsating or blinking sleep LED
I believe the pulsating or blinking sleep LED is instead controlled by the Power Management Unit (PMU) chip on the logic board.
这个答案有帮助吗?
得分 1
2条评论:
I could be wrong but IIRC the inverter boards are logic board specific. Ralph
完成的
Ahhh, so you're saying that though the light is actually on the inverter board, the style of blinking is NOT controlled by the board itself? Thanks so much!
完成的
添加一条评论
添加你的答案
TommyJames337 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 44
总计 1,793
