跳转到主内容
加入维修社区 - 创建账户
型号 A1369,1.6、1.7 或 1.8 GHz 处理器,64、128 或 256GB 闪存存储
What WiFi bluetooth card to upgrade my 2011 MacBook Air?
What WiFi bluetooth card to upgrade my mid-2011 macBook Air? wifi card to be able to connect to 802.11 AC? My hopes are to enable Apple Watch unlock along with continuity and handoff under High Sierra. Anyone try this would this work? Are the antenna wire long enough to reach the new card? Are extensions available if not?
Would this be the correct part# BCM94360CS2?
Thanks for the help guys.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
Yes, it will work. Make sure you get a dual-band card and purchase extensions just in case. Below is a replacement guide.
MacBook Air 13" Mid 2011 AirPort/Bluetooth 卡更换
Update (11/28/2017)
That is indeed the correct part number, no extensions should be needed. Look in the guide I posted earlier to help you replace/reassemble your laptop after completing the replacement. Good luck!
这个答案有帮助吗?
得分 1
5条评论:
Thanks, That card is a different number and looks different is that the 2012 card? I think I need a mid-2013 or newer card to use Apple Watch unlock feature. Which is why I was looking at BCM94360CS2. Also, . where do I find the extensions?
由完成的
I updated the answer.
由完成的
Thanks, much appreciated
由完成的
I don't see a link to the extension cables you mentioned in your comment or the guide. I know I found a set last week, but I can't find it now. Can you help me out with finding them or what I should be searching for, please? thanks!
由完成的
This did not work for me, the BCM94360CS2 is a longer card than the original, there was no way to secure it once installed.
由完成的
添加一条评论
Hey Jorge,
Did you do this yet?
I'm waiting for my BCM94360CS2 to come in the post.
I believe one of the antennas will be too short. you'll have to reroute it.
Regards,
Stephan
这个答案有帮助吗?
得分 0
1条评论:
Has anyone been able to get this to work? quicker tech is so dissapointing .
由完成的
添加一条评论
添加你的答案
Jorge 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 23
总计 3,724
