跳转到主内容
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
What is this connector underneath the logic board?
Hi, I noticed in the MacBook Pro 17" Unibody logic board removal instructions (here, step #23: MacBook Pro 17" Unibody MagSafe DC-In Board Replacement), there is a comment from someone else to watch out for a connector underneath the logic board. Unfortunately there was no mention of this in the actual guide, so I pulled the logic board off thinking it was stuck and ended up 1) pulling the connector off the logic board, which is really hard to reattach before installing the logic board again, and 2) pulling a wire out of the plastic connector itself. There are 3 wires going into the plastic connector: black, grey (pulled this one out) and silver (looks like a ground wire).
So my question is, does anyone know what this connector is used for, and do I need to somehow reinsert this wire before snapping it back onto the logic board? The comment said CCFL but that it wasn't sure. I wanted to get an opinion before going through all the steps of putting it back again. If it's some minor functionality that I can live with being disabled, might as well just leave it alone. Thanks.
The connector in question is coming out of the rubber hat looking thing in the middle of the photos.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
What you encountered is the rubber foam around the microphone over the years managed to glue its self to the grill work Vs staying with the speaker unit.
Sorry you got stung on this. When IFIXIT writes the guides the systems are still fresh so the foam was not sticky from age. I guess we need to make note of that in the guides.
这个答案有帮助吗?
得分 2
2条评论:
Oh wow, thank you! That makes total sense. Makes me wonder what the other commenter was talking about when referring to some CCFL connector.
完成的
Here's the new text: When lifting the logic board be careful! The rubber foam around the microphone may have adhered the microphone to the uppercases grill work so as you lift you could rip the connector from the ribbon cable.
* Take a small spatula and thought the fan opening carefully dislodge the microphone from the grill as you lift the logic board.
* To locate the microphone note on the next slide the small unit between the fingers of the hands.
完成的
添加一条评论
添加你的答案
ck244 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 188
