Error “press shutter release button again”
Can I repair shutter release button error?
这是一个好问题吗?
Released in April 2011, the D5100 replaces the D5000 as one of Nikon's popular consumer DSLR cameras. It features a replaceable Nikon F-mount lens.
声誉积分: 11
I just had a similar problem on my D5100 and was advised to send it back for repair. After comparing mine side by side to another at a camera shop, (remove lens and with camera on press shutter release button) the lower right corner of the mirror was binding with the stop. We were able to GENTLY pry the lower right corner of the mirror away from the stop (from the right, not underneath) and now it is functioning flawlessly.
评论:
THANK YOU SOOOO MUCH!!! That was the problem. Works perfectly again
由 Jack 完成的
Wow such an easy fix I had just put the camera on a shelf for 2 years found this and I have the camera back! Thank you so much I am sooo happy!
由 Joanne Boyd 完成的
Thank you very much your answer. You saved my lots of times. Thanks again buddy.
由 Sunny Sultan 完成的
You're a lifesaver, thank you very much. I was seeing big $$$ signs to get it fixed. Such an easy fix if you are very careful
由 kitkat.2005 完成的
you are savior.. after 2 years I already got the answer.. Thanks to google too..
由 Count Duku 完成的
声誉积分: 1
What if it’s doing the similar to myD5200 and it’s not the corner of the mirror sticking?
评论:
I had the same error message on my nikon d5600 and I have managed to fix it by using an external flash > I've simply attached an external flash to the body, turned the camera and the flash on and suddenly everything was working again. I shot some pictures and removed the flash. The error message disappeared and the shutter release button works again as well. I hope this helps for you :)
由 kircbarbi 完成的
Mine is d5200 having the same type of problem but in my case the mirror isn't moving only the left side lever is moving. Any solution please
由 remo1098 完成的
@remo1098 I have the same issue... there is a slight clicking sound but the mirror is not moving only the left lever... found any solution?
由 bernieambrosio02 完成的
过去的24小时: 8
过去的7天: 43
过去的30天: 187
总计 13,702
Hello, can this fix work for Nikon d5200?
由 Favoured 完成的
