跳转到主内容
这是由索尼电脑娱乐(现已重组为索尼互动娱乐)生产的游戏主机。PlayStation 4 Slim(CUH-2000系列)是比初版PS4更薄的替代型号,于2016年9月7日正式对外公布。
569 个问题 查看全部
PS4 Slim takes multiple attempts to turn on
Hey
I have a PlayStation 4 Slim 500gb(CUH-2016a) and has bit of a problem.
When I turn it on, 8/10 times it beeps, gives blue light and turns off. I have to switch off the outlet, wait and then turn the outlet on then attempt to turn on the PS4. If I don't turn off the outlet and press the power button there's no response, no blink or beep, completely cold. Sometimes it turns on in 1 attempt or sometimes even directly, sometimes you have to repeat the process 5-6 times. (Doesn't matter if you turn on from power button or controller)
When it turns on it works perfectly fine. Does not power off or anything. I have re-initialized it but problem persists. Also changed the power cord but to no use. I suspect a power supply issue. Any ways to resolve it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
Sounds like the power brick is faulty, unfortunately there is no guide on how to replace this on fixit but you could follow the teardown video for a rough guide on how to replace this.
这个答案有帮助吗?
得分 0
1条评论:
When you say power brick, does that mean the whole power supply or one specific component within that?
完成的
添加一条评论
Need help
这个答案有帮助吗?
得分 0
添加一条评论
Have you solved this exact issue? I had to replace my old PSU because of this back in 2017 and now here I faced the same issue on the second PSU and don't know what to do with it other than replacing…
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Saad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 1,748
