跳转到主内容
Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
Power, volume and mute not working after flex change
I changed the screen and digitiser, in doing this tore both the wifi and the power button ribbon.
I bought 2 power button ribbons from the US but neither of them work. Is there something I might be missing?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Small parts tend to have lower quality levels and it's not uncommon to receive bad parts. Did the replacement part look new or did it look like it was pulled from a device? Either way, that's a distinct possibility.
I would also check the connector the flex plugs into. Depending on how you damaged the flex, you may have pulled on the connector and damaged one of the solder connections. Use this guide, if you haven't already.
这个答案有帮助吗?
得分 1
1条评论:
The parts I bought were brand new, I tore the ribbon on the original one and had removed it properly. I've bought another one so hopefully that does the trick.
完成的
添加一条评论
添加你的答案
S2i 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 146
