跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
How to fix fingerprint scanner/home button no longer working?
A few days ago my home button started to stop working randomly, as in the phone would not recognize the button clicking, however the button itself still remained physically clicky. It would only register every 5th click or so. Soon afterwards, the button function ceased entirely. The fingerprint scanner still remained fully operational. I left the home button in since replacing it would restore the button, but not the scanner, and i preferred the scanner over the button.
Just earlier today, my fingerprint scanner began to behave the same way, only working every 5th try or so. Then it completely ceased to function.
My home button still physically clicks, and the touch id passcode page on the phone still recognizes fingerprint scanner funcitonality, but does not respond when i attempt to put a finger in. The home button function does not work, and the fingerprint scanner does not work.
I can easily restore the button function by replacing the home button, but is there anyway to restore the fingerprint scanner without going through apple?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I had the same thing happen but the print reader has failed to work. Can someone help me?
完成的
添加一条评论
3个答案
已选择的解决方案
Hi @trans1000. There is no way to replace the home button and preserve Touch ID. The sensor is uniquely paired with each CPU to be secure. If your original home button is dead, so the touch ID is dead forever.
这个答案有帮助吗?
得分 0
2条评论:
Anyway to troubleshoot the original button?
完成的
I'm Sorry, but the home button is not repairable. The only way is replace all the logic board with his original home button.
完成的
添加一条评论
Arkcyd would be correct in saying there is no way that an end user or an independent repair shop could replace the button with functional touch ID. However Apple certainly could.
When the Apple store replaces an iPhone screen, they actually replace the entire front half of the phone: screen, front camera, sensors, earpieces, and home button. It is the Apple store that has the "magic box" Horizon machine that pairs new home buttons to iPhone motherboards. So if you want a 100% fix for your home button you can pay Apple their standard screen repair price and they will get it done.
Alternatively you could buy a home button from third party for less than 10% of that price and swap in in yourself. That's only if you care more about cost savings than usable touch ID.
这个答案有帮助吗?
得分 0
添加一条评论
I'm stuck on the black screen of death everytime I lock my phone. I tried the forced restarting which works to bring the screen on and get back in but when I lock it again I'm back at square1. The only way for the lock screen to glow so I can swipe up and put in my code is when I force restart it, EVERYTIME, even though the phone is still on… I have a samsung a20 and it has no home button and you cannot take out the battery. My biometrics scanner is not working once I lock my phone and neither are my volumeup&down and lock keys(unless I wanna force restart, WEIRD I KNOW). Ive been “googling” all day and I cant find answer for this problem. CAN ANYONE HELP?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Trans1000 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 16,488
