跳转到主内容
加入维修社区 - 创建账户
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
6s Front Camera Hardware problem
Hi everybody. I have an iphone 6s with ONLY front camera is not working. (BACK CAMERA OK)
I update ios and restore phone, but the problem is still present.
I check all filter (only in continuity mode) the continuity is presente.
All capicitor are presente, no one is short.
Somebody plz help me..
I want to asl also something for voltage checking,
i can check voltage only with battery connected and power on the phone.. or must connect lcd or something else?? thanks a lot.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
@ags_studio Did you ever find any answer to this question? iPhone 6s Front Camera not working. Anybody have solution?
THANKS
完成的
添加一条评论
2个答案
已选择的解决方案
Take a look at page 21 of the iPhone 6S schematic, it covers the Forehead connector. There are three sections for the front camera: CAMERA POWER, CAMERA I/O and CAMERA MIPI.
The power section is self explanatory. Check to insure you have continuity on the filters and no shorts to ground (you have already done this!) and then check the voltages. You don’t need the camera connected.
If the power is good, then check, in diode mode, the I/O section. This is the control/communication between the camera and the CPU (AP…Application Processor). You should compare this to a known good device but in the absence of that, look for “normal” values (~.250 - .600). Finally, check the MIPI section. This is the actual data coming back from the camera. These are the square filters next to the connector.
An easy way to accomplish all of this is to probe the FCAM connector and compare values to a known-good device or ZXW.
这个答案有帮助吗?
得分 3
2条评论:
@refectio i dont have more this iphone ... but thanks a lot for helpul Answer Minho.. it will be help me next time :))
完成的
Haha! I hadn't even noticed that it was such an old question!
Oh well, like you say, hopefully it will benefit you or someone else on the future.
完成的
添加一条评论
There is probably a faulty camera or connection. There is not much you really can do besides replacing the front camera/speaker assembly
这个答案有帮助吗?
得分 -1
3条评论:
I forgot to write Trans.. i already replaced the camera but the problem still... :(
完成的
might be an actual issue with the logic board itself. See what apple says
完成的
Lol, Do not ask "Apple"! @refectio gave you the correct answer in troubleshooting
完成的
添加一条评论
添加你的答案
AGS 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 1,394
