跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Phone not charging after battery and charging port change
Completed a battery change and charging port change but phone failed to charge. I placed a USB Detector between the power supply and the charging cord and it shows no load going to the phone. Also hooked a test cable at the battery connection and plugged in the phone. It confirmed that there is no charge going to the battery. Battery showed voltage on the meter. What is the best way to confirm if the new charging port is bad? Or if the IC USB chip is bad? Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
since you changed the battery and charge port and cant see any charge with the v/a meter i would say tristar could be the problem
这个答案有帮助吗?
得分 3
2条评论:
Then the chip is the next step. I will follow-up afterwards. Thank you for your answer.
完成的
Was the phone charging before with the original port??? Check on the USB ampmeter first with the original port if it doesn't charge try it with the original battery and the original port if none work then it might be worth going for tristar
完成的
添加一条评论
添加你的答案
Bryan Solo 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 122
