跳转到主内容
加入维修社区 - 创建账户
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
backlight broke need help
Hello
changing my screen and forgot to remove the battery
= now the backlight fuse is broke the screen have spots and after 3-4 on/off
it gets black and needs a reset
so i need help changing the backlight fuse
any good repair service in EU ?
i live in sweden
Thanks you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
the issue youre explaining doesnt APPEAR to be a backlight issue. Screen having spots is usually a damage to the LCD itself.
my entire experience with backlight failures is that the image comes up fine, but there is no light illuminating the screen.
HOWEVER, if youre looking for backlight repairs, there are plenty of services to doctor the board. this is from an Ebay search, however, i would suggest looking for a more local, and reputable repair service.
https://www.ebay.com/itm/Backlight-Repai...
这个答案有帮助吗?
得分 0
2条评论:
Thanks for the reply
my problem is exact like in this video
https://www.youtube.com/watch?v=VeJ_iViO...
and he says it the back light :)
any way thanks for your input
完成的
yes, that is definitely a backlight issue. i apologize, i would not have described that as being "Spots" personally, so i gave you a different answer. What that is, is the LEDs in the backlight have gotten too bright for the diffuser. it shows the initial rays emitted from the LED, which implied the LEDs are recieving too much voltage.
完成的
添加一条评论
添加你的答案
Chris Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 96
