跳转到主内容
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
How to transfer home button to new digitizer
Bought digitizer without tools as i have them already. They do not offer a complete digitizer just by it self or i would have dought it. So instructions do not show how to take my old home button and transfer it to the new digitizer. So could some show me what to pull up so I don’t mess it up. I figured since they sold it the instructions would show this. Thanks a bunch. Perry
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Chances are you may have bought the wrong part.
Is your iPad mini the first generation one? If yes, the home buttons are usually pre assembled with the screens.
But if your iPad mini is the one with the touch ID then the home button needs to be transferred.
Ipad Mini 2 and newer use the digitizers with no home button pre-installed while the older iPad minis without touch ID use replacement digitizers with home button pre-installed.
这个答案有帮助吗?
得分 1
2条评论:
Ipad mini 1 , is the one i have , they dont offer it with the home button, but only in a kit with tools which inalready have. The kit with home buttonis for first time repairs. Would be nice not to have to go somewhere else to buy what i needed. But i will. I looked online and there are other places that have posted how to. Just thought the place where i bought parts would show what they said was “ easy to do “.
完成的
just an edit for you ben, the ipad mini 2, is the retina display, but it uses the same digitizer as the ipad mini 1. ipad mini 3 was the first one to use the finger print scanner.
Some cheaper sources do not have the home button or touch controller pre installed, and need to be transferred. most decent quality suppliers will however, sell them with these parts pre-installed, as you stated
完成的
添加一条评论
the home button flex is surface soldered. you will need to use the soldering iron to remove the flex at this point, and attach it to the new one.
[IMG]http://i64.tinypic.com/21nkuvl.jpg[/IMG]
这个答案有帮助吗?
得分 0
3条评论:
It would be great to see a tutorial on how to do this. Thanks for you help.
完成的
its a relatively simple procedure, but i will make a guide for it, and link it here in a bit
完成的
添加一条评论
添加你的答案
Perry Green 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 532
