跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
New Screen not working
I recently bought an iphone 6 plus from ebay with a smashed screen with the hope to replace the screen and use it. The smashed screen works, except from the touch doesnt, so I can see that the phone powers on as usual, battery holds charge etc. When I first replaced the screen, I got no reponse from the device, I thought I had damged something, but when replacing the original screen, it still powered on. I tried again, but still no luck, so I returned that screen assumong it was faulty, I then ordered another replacement screen, with the same problem. Am I just really unlucky and have had two dodgy screens or could there be some damage to a connnector I am missing? I dont think however this could be damage to a connector or otherwise I wouldnt get anything on the broken screen. Please help! Many thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
You most likely have Touch Disease on your phone. Google it :) Ask anything if you need help
这个答案有帮助吗?
得分 2
2条评论:
Hi, thanks for the speedy reply! I do know of touch disease, but the weird thing about this is the replacement screens do not show anything, no apple logo no sign of life at all, however I know the phone is working, because it is recognised in itunes, and can be put into recovery mode etc. Any thoughts?
完成的
Hold a flashlight to the screen when you turn it on and see if you see a faint image. Also when it powers on all the way, hit the power button quick to wake it and have your flashlight on the screen. It sounds as if there is a bad backlight circuit.
完成的
添加一条评论
I'd try a screen from a different supplier as you can get screens with manufacturing defects, I've had this problem before and it was solved with a screen from a different supplier.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rory highnam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 96
