跳转到主内容
Samsung的旗舰手机,Galaxy S8,发布于2017年4月。
304 个问题 查看全部
How to maintain water proofing?
What adhesive parts are required in order to maintain water proofing on the S8 after a front/rear glass replacement? I notice that often when the rear glass is replaced, many people say that despite putting adhesive, it will no longer be waterproof.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I believe that it is because it is not done in the same controlled environment as Samsung, and in most cases a far worse adhesive is used. The adhesive might be good enough to keep the back in place, but not tight enough the keep water out.
Even if you could get the same adhesive, you would need a completely dustfree environment, so there are not gaps in the adhesive, and put correct pressure and maybe even heat to stick it on correctly
这个答案有帮助吗?
得分 4
添加一条评论
I would say get the rear adhesive for the phone put it on the glass, put the glass on the phone press down on all edges, then put heat on the glass and put pressure on it after you have put heat on the glass. It may then be waterproof again .
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Naeem 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 6
总计 1,021
