跳转到主内容
发布于2012年10月23日。酷睿i5或酷睿i7处理器。配备Apple Fusion Drive.
208 个问题 查看全部
Power, fan at high speed, no image
Hi Community,
Got given a 2.3 GHz Core i7 (I7-3615QM) Mac Mini A1347 from a friend.
If it has had no power for a long period of time, it give the apple chime, then lights go out for a second, come back on and then fan spins at top speed. No image, nothing.
I have tried replacing the RAM to test if it was faulty = no change.
Have changed the power supply = no change
Not sure what else to try as I dont know alot about these devices.
Any assistance would be great :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I had the same issue with my 2011 Mac Mini, and I read somewhere online about the reflowing trick by putting it into the oven for about 10 minutes at 150 - 175 degrees Celsius. As it was my last resort, I couldn’t use it in a few months, I completely disassembled it to just bare motherboard, put it into the oven, heat it up, let it cool after, and it works now! It has been for a few months. Hope this helps you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jacob Harvey 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 94
