跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
How do I tell the difference between screws on my logic board?
I removed the logic board on my iPhone 6 plus, but the screws got all mixed up (clumsy I know). I was wondering if there is a way to tell the difference between them. I have read on some forums where even if you buy the kit with all the screws they are all in the same bag so I know there must be a way to tell, I just don't know what it is.
Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
iPhone 6 Plus 逻辑主板更换
This guide tells you where each screw and what size goes where on the logic board, hope that helps.
这个答案有帮助吗?
得分 1
3条评论:
Thanks for answering so fast! I used that guide to take it apart, but I don't know how to tell which screw is which size. Is there a simple way to do that?
完成的
If you google the screws for the phone you might be able to find out the lengths of them and then have an idea where they go. If not try just screwing them in, due to the sizes some might not screw into one hole in which case you know you need the longer screw and so on etc. If I get time later I'll try and find out by taking apart a phone I have here.
完成的
Just wanted to point this out that the 5 screws pointed out in step 12 of the guides you must not mix them up as the 3 red marked screw holes sit right on top of the board.
Putting a longer screw in those 3 holes will end up damaging the board which may result in paperweight phone.
完成的
添加一条评论
添加你的答案
Andrew Burton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 349
