跳转到主内容
德国汽车制造商奥迪的汽车修理和支持指南。
66 个问题 查看全部
Audi Q7 turned off and wont crank
Hello short story i was driving normaly took a turn and then steering wheel got heavy the car turned off, messages appear in the screen saying alternator not charging the batterie, eps malfuntion, gearbox limited , and the car wont even crank all accesorys worked but they where dimming so i replace the battery but nothing any tips?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
it was the ecu got water damage dont know how but it did
这个答案有帮助吗?
得分 0
2条评论:
How did u find out it was your ecu?
完成的
ecu is on the passanger side open the hood and under the wiper blade there is a black cover
完成的
添加一条评论
Following are the common solutions to kickstart your Audi Q7 once again:
- Battery Replacement
- Fuel Pump Replacement
- Ignition Switch Replacement (Electrical)
- Ignition Lock Cylinder Replacement
- Starter Replacement
- Camshaft Position Sensor Replacement
- Crankshaft Position Sensor Replacement
- No Start Diagnosis
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
carlos 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 39
总计 1,873
