跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
iPhone 6S - Volume down button
Bought the phone that apparently had a problem with the volume buttons. Opened it and the water indicator from the logic board was red, although the one near the sim tray was white, so I assume partial water damage. I took it apart and washed the entire logic board with 99% isopropyl and installed a new upper component flex cable to replace the buttons. the problem is that after all, only the volume down button does not work, just like with the old flex cable, I don't understand why. The volume down button works randomly for some time and then I have to keep clicking it for a few seconds until it works and then stops working after a few minutes. Have also tried switching the button covers and don't know what else to do to fix this. Would appreciate any help.
Update (12/15/2017)
Here's a picture of the connector itself, looks pretty good to me, no signs of corrosion that I can see.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
I tried cleaning it again with 99% isopropyl and a brush and it worked very good after I reassemble everything and then stopped working..
完成的
I follow exact same.. 99% isopropyl is not necessary use brush.. First you need to dissemble everything.. Then soak everything into 99% isopropyl.. Let it soak in about a day.. While waiting for it soaking.. Go to Online Shop and buy a new one.. The new phone works like charm..
完成的
添加一条评论
6个答案
已选择的解决方案
Here is a picture of the FPC connector to the volume down (FL4712, DZ4712, to C4712) and Schematic
这个答案有帮助吗?
得分 4
2条评论:
Can you please send a picture of the logic board showing where exactly that component is? Thanks
完成的
I added it to the pictures above :)
完成的
添加一条评论
Try cleaning the connector better and seeing if any components are missing. I think there is an inductor between the connector and the CPU so if cleaning more won't fix it ask me and i can show you where the component is.
这个答案有帮助吗?
得分 3
4条评论:
I've tried cleaning it a few more times but it doesn't work. What else should I do? Thanks
完成的
@gigabit87898 and RDC4, I didn't mean to step on the answer but had ZXW open for another person and added the pics below for you ...Hope it helps
完成的
Nothing attached @gigabit87898
完成的
look at the answer above
完成的
添加一条评论
Hi if someone can help
Plus and minus volume buttons not working. Silence switched and power button is working. Changed the ribbon cable but same symptoms. iPhone 6s 32gb?
Thanks
这个答案有帮助吗?
得分 2
添加一条评论
I have cleaned everything I could and replaced the cable with a new one and the problem returned after some time. Don't know what else to do. The weird thing is that is just the volume down button that is not working.
这个答案有帮助吗?
得分 2
添加一条评论
actually my mother bord is broken and volume buttons not working can you please send my the main print of volume buttons
这个答案有帮助吗?
得分 1
添加一条评论
how to iphone 6s voliom up dawn sort problem solution
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kraki 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 5
过去 30 天: 10
总计 8,253
