跳转到主内容
A1708/EMC 2978—于2016年10月上市,这台入门级MacBook Pro保留了它传统的功能键(相对于OLED触摸条)。功能键版本带有英特尔酷睿i5和2个雷电3端口。
216 个问题 查看全部
Need Replacement Coax Wifi Connector - Any place to buy?
Hi all,
after continues unplugging and plugging in (after various tests of the water daamged Macbook of my aunt) one of the Coax connectors for the wifi or Bluetooth antenna broke off and needs to be replaced now. Any idea where I can buy a replacement? I uploaded an image where I marked the said connector bellow:
I have no 100% size measurements but I think the size is 2.6mm lenght 2.6mm width and 1 ish mm height (used an rubbish ruler that I had laying around sorry).
There are certain names for these coax connectors to identify each one and not all have the same size I think, so any help on these to identify them would be helpfull. Thanks :-)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Sometimes if you cant find in a marketplace you can buy a "dead" motherboard. I usually keep some to be donor boards.
这个答案有帮助吗?
得分 1
2条评论:
@israel Thanks for the suggestion but my heatgun is not strong enough to get these off of the board so I had to use the ghetto method and put a lot of solder onto my soldering iron to get it off the board.. So buying an donor board is useless because it will end up damaged anyways :( Hope you understand my concern..
完成的
I do, There are way of finding those connectors on component level stores such as digikey or Newark. At least I would start there.
完成的
添加一条评论
添加你的答案
Musti 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 93
