跳转到主内容
加入维修社区 - 创建账户
1.8GHz dual-core Intel Core i5 or dual-core 2.0GHz i7. (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
Keyboard backlight not working!
I am currently owning a MacBook Air 2012, but the light of the keyboard is not working. I have asked apple for helped and we have gone through all the steps resets etc, but it still is not working apple said that it is a hardware problem. Does anybody know how I could fix this problem. I can see the icons when I press f5 and f6, but nothing works. any help would be appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
I think you'll need to test the ribbon cable connection on the logic board using a DVM. Review this IFIXIT guide: MacBook Air 13" Mid 2012 Logic Board Replacement. Jump down to Step20. You'll need to make a set of microprobes with some sewing pins as you'll want to test the voltage at the ribbon as it enters the connector.
这个答案有帮助吗?
得分 1
添加一条评论
Any significant events before the issue started? For example, liquid getting into the keyboard will usually fry at least one led; the keyboard backlight circuit on your MacBook model has 4 (or 6, I can’t remember) led’s wired serially, and fed by a ribbon cable supplying ~5vDC, modulated by a single chip that handles most things low current DC.
If the lights are fried, you could probably pick up a keyboard backlight replacement off Amazon or the like for maybe twenty bucks. It’s pretty much a drop in replacement, though you will have to gut the case fairly thoroughly to get at it.
If it’s the controller, the only real practical option is to replace the logic board, which really isn’t that practical, economically speaking. If you have a nice smt repair station setup and can find the chip (which you probably won’t be able to do, probably Apple proprietary, so perhaps a donor logic board) then you could replace the chip, but this is easier said than done, to put it mildly.
Dan’s solution will give you a fairly solid diagnosis. if you get a DC voltage of around 5V measured at the ribbon socket with the keyboard backlight fully on, then it’s the LED backlight sheet that’s bad. (You might need to measure AC and read the RMS voltage depending on your multimeter, due to the PWM driven circuit. I assume it would come out to something like 2V if you do it this way.)
if you get nothing... then it’s the logic board. Which, if it were the case, I would just learn to live without the backlight.
I’ll keep my fingers crossed that it’s the former.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Simon vn dr g 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 2,298
