跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Broke the lightning connector - parts stuck in logicboard
Hi.
My phone won't charge. I replaced the battery and the phone lasted for some time (20% remaining on new battery). Then I bought a new dock connector to try. The problem is that when I disconnected this, half of it got stuck in the connector.
Is this repairable? I have not been able to pull the parts out with my 0,8mm flat screwdriver.
Any advice and help is much appreciated!
Se link for pictures of the contact.
Thank you
https://imgur.com/a/Nyzkh
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
try a set of fine point tweezers
完成的
Bought some tweezers. Didn't help and I guess it's getting more and more damaged now...
Will this repair be comparable that of the Tristar replacement then? Maybe a repair shop that does microsoldering can do them both(?)
Thank you for your reply, daniel.
完成的
you will just need someone that can microsolder to remove the old connector and solder on a new 1
完成的
添加一条评论
1个答案
已选择的解决方案
It seems like corrosion made those connectors stick. You have to replace that connector and inspect around logic board to make sure there is no more damage on the logic board. If you are not a micro solderer id recommend finding a shop who can help!
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Bjørnar 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 5
总计 110
