跳转到主内容
加入维修社区 - 创建账户
此款 Power Mac G4 采用镜像驱动器门设计。
CD boot
Will not boot from Apple Install CD or Diskwarrior CD. Optical drive kick CD out when pressing "C" key. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Check your drive works, can you boot from hard drive?
由完成的 分享
添加一条评论
2个答案
最有帮助的答案
What install CDs have you been using? The mirror door G4s are a fussy set, will only boot from OSX 10.2.2(approx and above) CDs, not OS9 CDs (even the dual boot models).
If the machine is booting, check the machine can see the CD or DVDs ordinarily, if it isn't the optical drive has probably failed. The last few of those I've looked at I've had to put a new DVD drive in them as the laser had failed.
这个答案有帮助吗?
得分 1
添加一条评论
Try holding option down instead, if you manage to boot to the selection, then select the DVD.
What exactly is wrong with your computer that you need to boot from your install disk?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
pete surckla 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 4,731
