跳转到主内容
LG的旗舰智能手机,具有独特的滑出电池和可拆卸的I/O模块,支持多种硬件扩展选项。发布于2016年4月。
146 个问题 查看全部
Replacement 16mp rear camera is unfocused and "nodding"
The replacement camera focus is stuck and blurry, the quality looks arguably worse, and it "nods".
When I hold the camera still, the camera shifts downwards then back to the centre (when holding portrait-view-- left/right in landscape). You can see the camera lens move if you look directly at it.
I'm not sure what to do to fix this, or did I get a faulty one? When I opened the package, the camera was at the bottom of the box and not cushioned in-between the packing material so could it have been damaged during shipping.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi Kimberly,
That camera sounds like it's damaged, so you should consider returning that one and getting a new one.
- Jasen
这个答案有帮助吗?
得分 2
添加一条评论
Hi Kimberly, I had the same problem until I reboot the cellphone with factory settings a few minutes ago. It now works perfectly fine.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kimberly Fong 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 3
总计 611
