跳转到主内容
加入维修社区 - 创建账户
Sleep/Wake function activate's from back of ipad
I changed an ipad air 2 screen for a customer, original home button transferred..
tried a new screen and its the same problem.
So opening the iPad smart cover the iPad wakes up, but when you flip the cover over, and slap it on the back of the iPad the iPad goes back to sleep.
I have looked at everything super carefully and no rips or dents or anything, changing the screen still makes the ipad air 2 go to sleep, tried different covers, same problem.
any solutions?
Update (11/16/2017)
Its the magnet near the three screen connectors that are causing the screen to close.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Anyone??
My customer expect this ipad today :(
完成的
添加一条评论
1个答案
已选择的解决方案
The solution to fixing this issue is shown in this video link:
https://www.youtube.com/watch?v=Hzvf1aIs...
For the iPad Air 2 replacement screens, they do not come with the smart cover sensor IC's meaning you will encounter issues with the Smart Cover Sensor.
You will need to desolder it from the original screen that was on there (cracked one usually) then solder it to the replacement screen as shown in the video.
这个答案有帮助吗?
得分 5
11条评论:
"original home button transferred.."
And its the magnet near the screen connectors so I cannot really insulate it either..
完成的
So you are saying you are using the original home button?
Then I can only assume the home button cable got damaged or the home button cable IC got physically damaged when prying out the screen.
完成的
Dunno... the touch-ID and homebutton is working, but messing with the smart covers
完成的
I read somewhere about using black tape to weaken the magnet.. but how when its the magnet by the screen connectors causing the smartcover to go bananas?
完成的
Oh ****, the display image for the device threw me off, I thought this was an iPad Air without the touch ID / fingerprint scanner home button.
Since you have tried another screen I'm not sure how to go about this..
完成的
显示更多的6条评论
添加一条评论
添加你的答案
nicolay.94 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 2,624
