跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1366 个问题 查看全部
Charge port not working
I have a friend who sent his iPhone 7 plus into Apple because the charge port wouldnt work. He tried different chargers etc.
Apple says the frame is bent, so they wont work on it. The frame isnt bent. Sounds like a cop out to me by Apple.
I ordered a charge port and tested it externally and get nothing. I changed his battery and the phone comes on, so the phone is working. However, the original charge port and new charge port dont work. The strange thing is when the phone is off I can plug in the charge cable and it turns the phone on. So something is working, just not the charging.
iTunes doesnt recognize it, so I cant restore it. Im guessing at this point it's a board level issue. If so, what IC needs to be replaced?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
@israel is correct. the "USB" Charging IC you are looking for is U4001, just make sure the Charging Port FPC Connector or any of the components surrounding it have not been damaged.
这个答案有帮助吗?
得分 4
1条评论:
Thanks. The inside of the phone is in excellent shape. I inspected the components to see if anything else was visibly damaged, but there was nothing. Ill update you when I get it repaired.
完成的
添加一条评论
最有帮助的答案
You would be looking at the Tristar IC. Let me know if you need help!
这个答案有帮助吗?
得分 4
2条评论:
Thank you. Ill update this thread when I get it repaired.
完成的
Awesome! Looking forward to your response!
完成的
添加一条评论
Never saw an update, I have a phone right now I am looking at for someone doing the same thing. Battery is fine, not really wanting to do the charging port and order more parts if that’s not the fix. Did you find anything?
这个答案有帮助吗?
得分 1
1条评论:
The company I sent it to couldnt fix it either. I didnt try another company, but it's probably something to do with one of the charge IC's. I dont do board level repairs, so Im unsure. Trying a new charge port without installing it all the way is possible.
完成的
添加一条评论
Zahrealleobey how to fix iphone 7
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brian Wood 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 5,044
