跳转到主内容
The first-generation Ford Focus was manufactured in Europe from 1998-2004 and in North American from 1999 to 2007.
31 个问题 查看全部
bypass pat in 2002 ford focus
how do i bypass the pat system in a 2002 ford focus i have removed the key switch because it locked up and wouldn't turn
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
There is no way to bypass it. As long as the transceiver ring around the ignition lock is not damaged , you can buy a new Ignition lock with 2 keys, and either tow it to ford to have the keys programmed or have a lock smith program them.
这个答案有帮助吗?
得分 0
添加一条评论
There is a free open source obdII ford specific software called forescan
https://forscan.org/
Works with USB and Bluetooth obdII interfaces
To reprogram keys, you have to register your information in the software, this is to prevent just anyone reprogramming a key and stealing a car.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
arthurl.browniii 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 26
总计 2,649
