跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
iPhone 6 Plus Digitizer issues
I run a side business repairing iPhones doing anything that don't require micro soldering. My skill level is pretty extensive as to understanding of the board and etc. just don't have the equipment to properly repair micro soldering jobs.
I've came across what I accessed as a simple job.
Client stated that screen was busted just needed a replacement.
I did the repair and a few hours later client states that phone is being unresponsive to touch at times.
I checked the phone too make sure the flex cables wasn't bent or tore. Also disconnected the cables and reconnected to under proper seating of the flex cables.
Phone works fine for awhile but then starts to act up again by not being able to touch anything after a few power on and offs it became responsive again but shortly after it yet again acts up.
I push at the top right hand corner of the screen and it makes it work again sometimes. So I got another screen and tried it. Same problem. Another screen to be %#*@ sure it wasn't the screen. Again it acts up.
Tried 3 screens and problem was present in all 3 screens, mind you they was from the same supplier what's the chances of all 3 screens doing the same thing? I use cellphoneage.com for my screens and of all my time doing tons of repairs I've never had this problem. I've cleaned the digitizer connector with alachol and a small brush. Nothing helped.
I attempted to put a piece of paper on top of the connector before I put the plate on to insure a solid connection and it actually helped to some extent. Although it wasn't a 100% fix because it would still sometimes act up.
I inspected the digitizer connector on the board to make sure there was no damage there and all the connectors are there and no damage seen.
I'm thinking maybe it need a new connector on the board to the digitizer. despite the good shape connector, also in not sure if this problem was preset before my repair.
Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Also forgot to add that when I lift the screen up like I'm taking it out, it will work.
完成的
If it is happening to all 3 screens, it's definitely a board related issue. My guess is when you put the shields back on and close, you are putting just enough pressure on the board to flex it ever so slightly. Meson and Cumulus sit on the opposite side of the Flex connections.
完成的
添加一条评论
3个答案
已选择的解决方案
The phone has "Touch Disease". Classic symptoms for the Iphone 6 Plus. The Meson Ic will need removed, run a jumper on the M1 Pad and put back on... About a $50 to $60 fix and it will be perfect.
这个答案有帮助吗?
得分 1
3条评论:
Are you charging 60$ for Touch Disease?
完成的
@refectio , Sorry... Wasn't trying to advertise pricing. But yes, I charge $59.95 for Meson and M1. I add $20 additional if I have to pull Cumulus...not including parts
完成的
Hi! I just wonder if this forum is still alive. So. I have a 6 Plus. The digitizer is cracked, bought a new one and it doesn't work. The old one which is cracked also doesn't work at all. I am almost sure the problem is in the logic board not in the digitizer. The LCD works just perfectly, but the digitizer refuses to react anyhow to touch. I read many forums, I watched many videos on YouTube. Such fixes like nano sim, do not work for me. Rewa Technology has a video replacing the Meson Ic I suppose. Before unsoldering and resoldering the component, I just wonder, shall we have any voltage on the flex connector of the digitizer? How can I figure out that the problem is in the Meson IC and not in a "poor" capacitor somewhere on the logic board? And what do you mean by making a jumper on M1? Sorry, I am rather new in iPhone reparation. Would highly appreciate any help. Thanks!
完成的
添加一条评论
最有帮助的答案
Try to put an test screen without anything on it, no proximity or shield,
Maybey the the shield touches some component that make the phone not work properly
这个答案有帮助吗?
得分 1
添加一条评论
I had this problem, in my case it was a manufacturing defect from my supplier turned out when screen was pushed down onto phone screen would not work. It was flex cables were slightly shorter. I had phone in my cupboard for about a month then tried a screen from my new supplier and it worked a treat.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Frost tech repairs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 5,307
