跳转到主内容
Released May 2015, identified by model number SM-T350. Features 8.0″ TFT capacitive touchscreen, 5 MP camera, Wi-Fi, GPS, Bluetooth.
118 个问题 查看全部
Why does my tablet overheat and restart?
So, I have had my Galaxy Tab A for almost a year now and his is the only issue I'm having. My tablet will be hot to the touch (sometimes not) and will the commence to shut off instantly and then right after restart. After it turns back on, the issue will usually reoccur within 3-5 minutes. Also, when I change it, it will have absolutely no issue. To add, it will charge very slowly. This version have will not let me access my internals. Send help fast!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
No. This is unfortunately not the issue. It will have the issue at idle to.
这个答案有帮助吗?
得分 1
添加一条评论
It's most likely because you leave to many apps open and your device can only have so much make sure when you close a app that it's not still going in the backround of your device!
这个答案有帮助吗?
得分 0
1条评论:
It has been almost a decade, and still Samsung has not addressed the issue with overheating. My advice is to follow the many others and buy another brand. I have heard of Samsung soaking thousands of dollars off customers in cascading repair bills... plainly because their product is defective in its design. So bottom line... don't buy Samsung!!!!
完成的
添加一条评论
添加你的答案
UnlimitedREKT65 :P 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 3,086
